rear brake sticking... any ideas
newby92
3.2 swapped 95
ohio
every now and then the driver side rear brakes will drag for the entire ride... no the parking brake is not on... i thought that the first time but its not... but the brake is applied enough to make it smoke when i am done driving... also it makes for a ****** ride so its really annoying... could it be the rusty p.o.s. proportioning valve in the rear... or prolly just a caliper???
Rockledge
Pluggin' away
Connecticut
In order of probability:
1. Crusty slider pins
2. Failing brake hose
3. Bad caliper
Unlikely that it's the proportioning valve.
pete315
Long Island, N.Y.
change 1,2 and 3. if it got that hot, the caliper is wasted. hose cheap enough. I would do both sides. and change both rotors. I went thru same ordeal 6 months ago. pulled into city and my right rear rotor was glowing orange.
projectSHO89
SHOless In St L
Add rusty e-brake cable to Rocky's list as #4 and bump the caliper to #4 if you're in the Rust Belt.
Mine was the hose...
Steve
shofun93
Rootstown, Ohio
where are you in ohio, I am near Kent State andjust completed an entire rear brake job for about $250. Let me know if need help
shofun93
Rootstown, Ohio
let me know where you live, I am near Kent State, I could lend a hand. I just finished a rear brake job
Jason
