Rattling sound from the engine
jimtash
nc
I have this rattling sound coming from motor that's been present for a while now and I'm trying to figure out where it's coming from. The problem here is it's hard to detect when the hood is open but I know for sure it's there. It usually happens at take off and then disappears as the revs increase. I've also isolated it to the front part of the engine and I'm pretty sure it's external. Any ideas here?
Can you post a sound clip?
AREA 91
PA SHO SHOP
Area 91
Pull the accessory belt(s) off and run the car again. This will tell you if its an accessory or not.
Vnuk1
Mr. Mayhem
Minnesota
I'm gonna go with Catalytic Converter Shields on this one.
mike25
92 sho
south carolina
i had the same problem it was my catalytic converter shield the weld broke loose and it made a loud rattle.
jimtash
nc
I replaced the Y-pipe with a Magnaflow a while back so I really can't say for sure. I looked at them and the shields seem to be on there tight.
stlgreensho
93 ATX SHO
St. Louis
The sheild may still be loose. A cheap fix is taking a hose clamp and putting it around the shield on both sides and back.
Worked for me.
