Rattling Door
Dr.Evil
No Dif Pin!
Sparks, Nevada
I have a rattle that is getting worse and I can't find it. It sounds like it is comming from the read passenger door, like in the latching mech, but am not sure. I can locate it because it only makes noise while in motion. Anyone else have this problem?
Dr. Tweak
Mad Scientist
Northern Vermont
Just set the cruise and then climb back there and check it out.
I was at this bodyshop one day and I saw this NICE brand new RV, one of those huge ones, totalled. I asked what happened, they said that the owner was this older guy who apparently didn't know what cruise control was... he set it and then went out back to make a sandwich. headbang He was okay I guess...
Dr.Evil
No Dif Pin!
Sparks, Nevada
JDLangevin:
oh
SHOPWR
beresford SD
ever since all my window motors were replaced in my 94 SHO all my door panals makes noices. i dont know if there is something that they were supposed to apply on the door panles to stop from creaking and what not. i dont know what i can do about that does anybody have any suggestions as to what i can use to stop the noises ?
shobikes
ashevegas nc
I have the same friggin' problem, only mine's the rear driver's side. I have replaced the latchpost, moved the post in, moved it out, moved it up AND down, loosened and retightened the hinges while the door was shut AND open. I have pulled the door panels and found nothing loose inside. I took the problem out of my sig, just in case ignoring it would help it go away. I'm thinking rear STB's and SFC's might be the only answer, since it's gotta be body flex around the door that causes this. It gets better and worse, but hasn't ever gone away. Right now it's only bad on rough roads. Good luck - if you fix yours, tell me how you did it!
Mostly I've just been turning up the stereo...
<small>[ March 05, 2004, 11:22 PM: Message edited by: shobikes ]</small>
shobikes
ashevegas nc
Update -
The rattle's not in the door, much as it sounds like that. It is coming from the upper shock mount, or something else in the upper rear suspension. I crawled back there while my girlie was driving, and it sounds like it's coming from beneath the rear qtr window. I even pulled off the interior trim. I think I'm going to get a ride in the trunk to further isolate it. I'll keep you posted. We're gonna beat this thing, dude!
