Dr. Tweak
Mad Scientist
Key on Engine Off:
114 IAT out of range, this is nothing, right?
173 02 sensor not switching, 02s need to be replaced?
542 Fuel pump open, bad ground or always on, what does this mean?
Key on Engine On:
114 again
225 Knock sensor not tested (ignore if not pinging), what does this mean? I did not hear any pinging.
536 Brake On Off open or shorted to ground, I know you have to tap the brake when the RPMs go up, did I not get it good enough maybe?
Cylinder Balance Test
9 - No problems found
Solenoid/Relay test:
Did this, but the CEL just came on and stayed on. Is there something else you're supposed to do?
Key on Engine On:
114 again
