Radiator Replacement
ToledoSHO
Toledo, Ohio
93 SHO ATX
Ok, So i have been developing a leak for awhile and decided to take a look. Seems as though the radiator has a hairline crack in it. And when my parents had it replaced cause of an accident they put the wrong one it. How much does it cost for a replacement? How hard is it to do yourself? Also where and any recommendations for a replacement?
Thanks
Matt
nefordfan
Hastings NE
I did mine about a month ago, around 150 dollars at advance auto. Take all the stuff off of the top of the radiator, I also removed the battery to make moving the wiring harness easier. The hardest part is removing and replacing the lower radiator hose. If it hasn't been replaced in a while order a new hose while you have it apart.
