Radiator replacement walkthrough
SHOwener1986
I have a 93 ATX and the RAD leaks :cry: . Im going to replace it with one from advanced auto. Anyone with some input about the removal like directions or hints to make it go smoother would be very helpful. Thanks :biggrin:
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
The trans lines can be trouble trying to get loose,but you can leave them still on the radiator just disconnect the lines from the trans and the other line at the trans cooler.The bottom line gets hung upon everything coming out.I've done it both way's but If you can get the lines off at the radiator and leave them in the car it makes it easier to replace. :thumb:
I don't know if Autozone rad's come with the cooler line fittings on,the Ford rad's don't,but make sure they are on the rad before you install it in the car.l :oops:
