radiator fan
Doug Waschenko
New York
The cooling fan isn't coming on at the correct temperature. As a matter of fact, I don't think that it is coming on at all.
The female plug socket was replaced and if I hot wire the fan to the battery it works.
Also if I put the a/c on max, it's not coming on either.
The temperature gauge seems to be working correctly.
Does anyone have some suggestions on how to test the system and what to look for?
projectSHO89
SHOless In St L
I posted a complete diagnostic procedure awhile back.
You should be able to find it without too much problem with the SEARCH feature.
Does your AC system actually work when you turn it to MAX?
Steve
