radiator fan check
Moneypit
Houston Texas
Just changed out an a/c compressor. Everything is back togather but my radiator fan is not turning on. Any way to check/test to see what is wrong?
sideSHO
East TN
You can unhook the fan and run 12 volts and a ground to see if the motor is good.If it runs then the switch is probably bad.
Axianator
I am a banana!
Roanoke, TX
You can also test fan operations by tapping that "MAX A/C" button on your climate control. ;)
I assume you've checked your connections at and around the compressor?
