Radiator(ATX cooler) problems
Blast7
Rochester, NY
I bought a new radiator today and I am getting ready to put it in but it has two holes on the side(I presume for the ATX cooler) which is fine and dandy except I have an MTX. It did not come with anything to plug it up and keep it closed. Can I just go to an auto store and find something to screw into these. I am probably going to head to the store soon but if anyone has a few ideas in the meantime then let me know. Thanks.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
S
slosho
Guest
Just leave em' alone. It's not going to harm anything, actually it may vent the moisture that may build up in there into steam and let it out the vents instead of rusting the core from the inside. Just a thought.
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a "PCV" line
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
olympic
Saskatchewan, Canada
No, nothing will leak. The ATX pumps tranny fluid through there to cool it off. It's a totally sealed chamber from the radiator. So leaving them open won't hurt anything. But if the rad is ever removed and used in an ATX car the cooler should be flushed incase any dirt got in there.
Blast7
Rochester, NY
Thanks Olympic. I wasn't sure how it worked. I installed it just the way it was and so far everything seems to be going well.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
