rangerj
JH,
The fittings for A/C are different. An R-12 fitting is a threaded schrader valve. The R134a fitting is a "quick connect" fitting, that is, no threads.
For an R-134a conversion, the R-134a fittings are threaded on to the R-12 schrader valves. The low pressure and high pressure fittings are two different sizes, just as they are for R-12.
Are you trying to connect a high pressure coupler to a low pressure fitting? rangerj
