Quill sleeve and throw out bearing pin
Sh03d
Sho Ed
Fairfax VA
Sorry for posting this around the forum but I need help pretty bad.
Wail installing my brand new quill sleeve is was quiet hard to get on and wail hammering on it the back of it broke off. :frown: I can't seem to find just a quill sleeve for sale. I'd rather not buy a whole throw out bearing kit.
Also the throw out bearing pin snapped off wail removing it. Can I use anything else?
Thanks in advance. I really need to get this car moving.
RJ-92
Crappy NYS
I used a nail fo rmy TOB fork pin. Hasn't got jammed up in anything yet. ~10K miles and track time.
Sh03d
Sho Ed
Fairfax VA
A straight nail or did you curve the end at all? Also I would want a snug fit but lose right?
SHOracer14
Me-0 Diffs-6
Toledo, OH
You really don't even have to have anything on it... The plastic piece is just to hold it on the fork for installation purposes (hence why it's only plastic). I personally feel better knowing something is there though... when I broke my plastic piece I used a small cotter pin and made sure it didn't interfere with anything.
Sh03d
Sho Ed
Fairfax VA
Thanks for the advice. The soonest I can get a throw out bearing kit is by Friday. Couldn't find a quill sleeve by it self soon enough. The cotter pin idea sounds best.
Bizzy
I've got a few of the nylon pins if you need one.
TRSCobra
Washington
Try cleaning the quill that the sleeve slides over before you put the new one on. I noticed mine had some corrosion on it after I took the old sleeve off.
Sh03d
Sho Ed
Fairfax VA
I cleaned it with brake clean and a cloth and it seemed to clean decently well. I will try using a green scratch pad to clean it off a little better.
