Bank of SHO
I just finished installing my water pump, but I'm second guessing myself on the o ring position. I know where the thin o ring goes - in the grooved portion of the pump that connects to the block.
I'm not sure about the thick o ring that seals the metal tube from the engine to the pump. Does this o ring slide over the tube from the engine to the point where the tube bulges, or does it sit on the end of the tube? I installed it on the ****** portion in the water pump and used dielectric grease to hold it in place in the pump before mounting the assembly to the engine. Was this incorrect? What is the purpose of the engine tube bulge?
