Quick suspension question
kdanderson5
Iowa
Will a strut/spring assembly off of a 95 Taurus NON SHO, fit on a 93 SHO? I found a salvage yard that will sell them for $45 bucks but he has to pull them off to make sure they are good. I don't want to waste his time if they will not fit on a 93, I told him I would check into it and call him back ;)
Thanks!
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Yes it will fit but I would go new if you are doing all of that work. Chances are the suspenion will be just as old and saggy.
Shoaz
Studly dood
Scottsdale, AZ
And don't do just one corner as the spring rates will likely not match. Do both fronts if you can.
The springs will likely be softer than the springs on a SHO, but as mentioned they're all going to be pretty soft by now as well as the struts. Check prices on Monroe quick struts, which are fully assembled and all new.
