Quick fuel rail Q.
nik97
Mile high
Hey all. Does anyone happen to know the thread size/type and pitch of the banjo bolts/fittings on our rails? Also, I assume these bolts are "face seal boss" -straight thread with a sealing washer. What comparable AN elbow-hose adapter size would I select? I'm trying to build a parallel fuel rail setup and I need to order the correct fittings. I'm basically looking for the elbow fittings used on Josh's High Flow regulator/fuel rail set up... http://www.shonutperformance.com/High-flow_FPR_parts_closeup.jpg
Thanks!! :salute:
shomethe$$$
Washington D.C.
I did 6 AN throughout
banjo is 12mm X1.25 summit has them EAR-991945ERL
I just did my dual rail setup, I had two defective 90 degree AN fittings which they gladly sent out, I'm slowly changing everything over to Aeroquip, just can't sacrifice anything when it comes to fuel.
