JoeHoe_SHO:
Okay, I'm checking out MIDWEST SHO's maint. packages...anyone have any experience with AutoLite Plugs? Do they fit correctly? Am I better off getting MotorCraft Double Platinum ones? What about the wires from MIDWEST SHO? Thanks!
I doubt anybody would recommend using autolite plugs. The only plugs you should use are the motorcraft oem factory plugs (AGSP32PP). Below are places where you can get parts cheap. I took the information from a well respected SHO owner named Sdpatt that frequents the shoforum. GOod luck with everything, and don't forget to take your time and be careful.
I. Top End Engine Work
1) Valve gap check/adjustment of all 24 shims - 60K
...Requires gapping tools and supply of shims
2) Spark plugs - 60K
...Motorcraft AGSP32PP (6 ea.), O'Reilly $3.79 ea., FordPartsNetwork.com (FPN) $3.99 ea.
3) Plug wires - 3.0L: 120K, 3.2L: 100K
...3.0L Motorcraft WR-4033, FPN $83.98 (will fit the 3.2L)
4) Valve cover & plug well seals - 120K
...Fel-Pro VS50378R, AutoZone.com $71.99
5) Intake manifold gaskets - 120K
...(required only if black finish is chipped)
...Motorcraft E9DZ-9439-A (2 ea.), FordPartsOnline.com (FPO) $12.14 ea., FPN $12.49 ea.
6) Thermostat - only when not functioning correctly
...Motorcraft RT-1112, FPN $19.99, FPO $17.77
7) Oxygen sensors - 60K
...3.0L Bosch 13942 (2 ea.), AutoZone $38.99 ea.
...3.2L Bosch 13223 or 15716 (2 ea.), AutoZone $49.00 ea.
II. Front End Engine Work
1) Timing belt - 3.0L: 60K, 3.2L: 100K
...3.0L & 3.2L Gates T248, RockAuto.com $34.77
2) Accessory belt(s) - 3.0L: 60K, 3.2L: 100K
...3.0L PS-WP, Gates K040500, RockAuto.com $11.87
...3.0L A/C-Alt, Gates K060445, RockAuto.com $12.90
...3.2L Gates K060854, RockAuto.com $22.55
3) Water Pump - 120K
...(remanufactured-lifetime warranty)
...3.0L A1 Cardone 57-1373, O’Reilly Auto Parts $61.99
...3.0L A1 Cardone 57-1373, RockAuto.com $49.99 (warranty?)
...3.0L, NAPA WP 571373, NAPA Auto Parts, $41.99 (LLT warranty)
...3.2L A1 Cardone 57-1458, O’Reilly Auto Parts $67.99
4) Water pump gasket set - only if desired, not usually required
...Fel-Pro ES70425, RockAuto.com $4.88
5) Lower radiator hose - only if desired, not usually required
...Motorcraft, FPO $12.87
6) Crankshaft position sensor - 3.0L: 60K or 120K, 3.2L: 100K
...Wells SU242, AutoZone/AutoZone.com $34.99
7) Front main crankshaft oil seal - 3.0L: 60K, 3.2L: 100K
...National 710220, RockAuto.com $6.26, O’Reilly $7.99
