pulled some codes...
EMB2580
Mike is a L O S E R
Zion, Il
I pulled the codes today (KOEO) and got 11,15 and some that were not on the list on SHOtimes.com...I think I might have counted the flashes wrong, but I know 11 is correct. Any ideas?
jedhead
westminster,ca
15 is PROM checksum error. You usually get that code when you have a LPM installed. 11 is a pass.
Bob
jedhead
westminster,ca
Lifetime Performance Module. aka chip. In most versions it is a PROM chip with a new tables for the EEC-IV engine computer to follow. Very early versions also contained new programming.
Bob
EMB2580
Mike is a L O S E R
Zion, Il
Oh ok. I'm not having any problems or a CEL light, just watend to check codes for the **** of it.:thumb:
EMB2580
Mike is a L O S E R
Zion, Il
CEL on again tonight..UGH!!
Ok, well I pulled them again, this time i'm sure I counted them right this time. I got 11, 41 and 59. 41 says HEGO sensor circuit indicates system lean (rear) what does the mean? IIRC it stands for heated exhaust gas something-or-other?? and 59 is low speed fuel pump circuit open?? Oh, I juust noticed this: I got these codes doing a KOEO test but on shotimes.com it says 41 is only a KOER code
SASHO91
Zoom Zoom
San Antonio,TX
Its your O2 sensor. might as well replace both.
Your right, the 41 is a KOER code, but the KOEO with store it in the Memory. Which is why you got it in the KOEO.
Have you stalled the car at all?
EMB2580
Mike is a L O S E R
Zion, Il
Um not recently, why? LOL, I thought the CEL light came on because of a broken hose.
EMB2580
Mike is a L O S E R
Zion, Il
I better get it fixed and fast then, LOL, I know how f**ked up a car will run w/ a bad O2. Thanks man!!
SASHO91
Zoom Zoom
San Antonio,TX
I also forgot to mention that it could be an intake leak. One of the cupplers on the back set of runners could be leaking. I would check it out first.
Sorry i jumped to conclusions....
EMB2580
Mike is a L O S E R
Zion, Il
It's ok. the rubber hose that had a hole in it goes to the charchol canister or whatever the **** it's called. it comes out of the intake between the IAC and TB and goes down behind the coil pack.
EMB2580
Mike is a L O S E R
Zion, Il
No, I pulled it off, cut just below the hole, then put it back on.
SASHO91
Zoom Zoom
San Antonio,TX
Oh..
Try clearing the codes.
You can either, disconnect the battery for awhile ( i normally do it overnight), or pull the jumper while you are pulling the codes. you have to pull it when it starts reading the memory codes.
