40BelowSummer
Okay these were the codes I got:
KOEO
157 =MAF circuit below min. voltage
172 =HEGO indicates system lean (RH)
176 =HEGO indicates system lean (LH)
177 =HEGO indicates system rich (LH)
543 =Fuel pump seconday circuit failure
KOER
136 =HEGO indicates system lean (LH)
Please help me diagnose what these could mean and what I should check on. Being a newb @ SHOS and engines in general it is difficult for me have any opinion on whats wrong.
How could it read lean & rich at the same time?
THANKS!!!!!!!!!!!!!!!!!!!
KOEO
KOER
Once more yor O2's are probably functioning properly and most likely do not need to be replaced. The reason for the 176/172 code is more than likely related to the malfunctioning MAF. When you replace that, your problems w/ the lean condition which your oxygen sensors are reading should go away w/ it. The reason you were told that is because both are reading it not just one. It is highly unlikely that both would be displaying that same lean code if they were shot and if that was happening it would be the HEGO not switching code (I dont know the code # offhand) instead of reading lean.
