Lots of Codes-where to start
eeugross2
PA
CE light is on intermitently. Runs pretty good except sometimes cruising it shudders. If I lock out overdrive it seems to run better. Replaced Cam Sensor not long ago. Here are codes
176 always lean left
177 always rich left
212 loss of IDM input to ECA or spout circuit grounded
215 coil 1 failure
217 coil 3 failure
543 fuel pump secondary circuit failure
I'm thinking replace the coil, however I hate throwing parts at a problem just to find it was something else. Car is a 94 with 81k mi. Plugs aren't too old but I haven't replaced the wires.
Any help is appreciated.
Jim
and then reset the codes and check each day till you figure out what is going on. I suspect some of those codes are very old and not helpful at this point.
eeugross2
PA
Cleared memory and will see what codes come up first. Thanks for the suggestions.
