PTU gear oil chane
SilvererSHO
50 miles north of Minneapolis, Minnesoder.
Yea I get where your coming from now. It’s a damn shame they couldn’t figure it out themselves but I guess the converter was in the way of getting the ratchet in there? That’s why I suggested to them to follow the passenger side axle through the wheel well. I’ve done it several times and once the wheel is off it literally takes about a minute to get the extension in there and remote plug, probably less.
Either way, another reason to go with catless downpipes.:cool:
Sho_Ride
Texas
Thought about that too, where I live they don’t do an emission test. I would imagine that would increase HP? My sons came with a muffler delete but may want to add them back on. He’s not sure that he like the extra volume.
HMINUS3505
Fishers, Indiana
Wouldn’t it be logical to say that if they added a drain plug later on that they realized that it wasn’t a lifetime oil? And after coming to that realization they would have sent every Ford dealer instructions on how to change the fluids? Although I am no mechanic, I’m handy enough to do this type of thing as well as having a garage to do it in. My son is stationed at Ft. Bragg and lives in the barracks so there is no place him or I to do it. Two local Ford dealers in the area but only one has done it. It’s aggravating as **** making several calls to finally find someone that understands what’s involved with a fairly simple fluid change. Thanks to all for the replies.
I was stationed at Bragg (I'll never call it Liberty), do they no longer have the auto skills center on Yadkin Rd anymore? Granted, I haven't been to Bragg in nearly 20 years at this point, so it might have changed.
J persons
Natchitoches, LA
I have a lift so there is no reason to remove the wheel for access. the drain plug is easy to see and once it's broken loose, it's easy to remove. I make a oil drain 'chute" from aluminum foil to keep the gear oil off of the cat and catch it in a graduated cup so I know how much drained out. I fill through the vent tube using a syringe, but go slow filling or the gear oil will get everywhere.
