oboytroyman
Troy
i think i need a new one. sometimes the car is hard to start, just cranks over like its not getting enough gad but once it starts runs good. does it kind ofinfrequently..
It's real easy, open up the fuel cap to let the pressure out.. Just pop the clips off to take off the hose fom the old filter..Look at the new filter and install it with the arrow pointing towards the engine..Done.
I remember relieving back pressure by pressing the shraeter valve on the engine intake... i put a pvc tube in it and the other end in a cup; then I stuck a pin through the tube to depress the valve....no gas leaking all over the engine this way
yes.. or do this..
stupid question "IN" is from the tank right... on the filter i have no arrows just IN on the flat side???
remember...blow, not suck, otherwise your ears will pop from projectile vomiting instead.
