Problem with rear brake caliper
Bryan
What do you get when a deer & SHO cross at 45mph?
Morgantown PA
Hey guys I recently got a 92 SHO and one of the problems I am having now is I can't seem to bleed brake fluid into the new caliper. I have the bleeder valve off all the way and I even removed the brake line and still no fluid is going to that caliper. I can feel pressure in the brakes when I step on them, but no matter what I do nothing is coming out of that line going to the passenger side rear caliper.
kevinspann
Don't take my advice.
Richmond VA
Did you remove the rubber line from the caliper? It has likely collapsed internally and needs to be replaced.
