I know many have probably ran into this problem I am having, but this one has been by far the worse of all the SHO's I have owned or worked on.
Basically, when someone works with the exhaust and removes the y-pipe, somehow they end up spreading out the exhaust studs apart like: / \ when they're suppose to be like: l l
With that said, there is no way I can get the y-pipe bolted back up. I had a hard time pulling it down, had to yank the crap out of it and pry.
So, is there any special type of tool to draw these studs inward?
I tried to see if a c-clap would do it, but there is no room what so ever. I then tried a set of pliers, but it looked like it was about to chew up the pipe, since that was the only other place to put the other end, and make for a bad seal when the y-pipe is later installed.
Any other ideas, or solutions?
I hate ATX y-pipes!
I hate ATX y-pipes!
