Power steering Problems & other front end probs
T
ThatSHOkid
Guest
ok i have some problems
1) my power steering always squeals, especially when cold? do i need a new belt or to be tightened? prices?
2) when it is cold i notice my car is tough to steer when it is not warmed up. perhaps power steering rack? prices?
3)when turning occasionally my car makes like a crunching type noise/old creaky door opening. what can that be? is it air passing though? my gf says it sounds like a boat when i turn.
thanks guys
1993 White/Tan SHO MTX 98k Miles
[*] Performance: Sho Shop Y Pipe * Coneless & Boxless * 80mm MAF * S & B Motorsports Concial Filter * Ted B Performance Chip
[*] Appearance: Colgan Custom Bra * "SHO" Windshield Banner * Blacked Out "SHO" Lettering * Ventshade Sunroof Wind Deflector & Vent Guards * GTS Headlight Blackouts
[*] Audio: Sony 10 Disc Changer
[*] Lighting: Eagle Super White Headlights * American Products Company Super White Reverse & License Plate Lights * Blazertech Foglights
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The AIM Screename: KingPin641 (a NESHOC member)
"Drive it like you stole it!"
First you need to tighten the belt. You must loosen the 14mm bolt through the center of the tensioner pulley then turn the 5mm Allen head bolt on the top of the tensioner in the CW direction. This Allen head bolt is a bugger to reach with anything other than the dedicated 18" long, T-handled Allen wrench.
A slipping belt could definitely cause hard steering problems. With the pump properly spinning, now you should check the fluid level.
The early SHOs were prone to a fluid resonance sound especially when turning right. This is more of an annoyance than a functional problem. The crunching noise may be the upper spring pad rubbing against the inside of the strut tower. Again, this is more of an annoyance than a functional problem, but it can be alleviated by applying some silicone grease (Sil-Glyde) to the areas of interference up inside the tower.
Ahoy matey,
Scott
[This message has been edited by sdpatt (edited 01-04-2002).]
T
ThatSHOkid
Guest
thanks scott! me dad and myself will have to take your advice and tighten and ****. hopefully my car won't soun liek a sqeualing SS SHO
