power steering fluid
L
LL-Cool-A
Guest
I am running low on power steering fluid and I was wondering what kind I should get for my mtx 89 sho. I bought the car about 4 months ago and I haven't added or replaced the fluid yet but now since it is low I need to do so. Thanks
olympic
Saskatchewan, Canada
If it's low, it's leaking somewhere so get it checked out first. The best fluid is synthetic ATF(yes, tranny fluid.) Mobil 1, amsoil or Redline are good brands. Here's how to do a power steering flush and refill:
Jack up the front of the car so the wheels are off the ground and disconnect the power steering return line at the resevoir and place it in a bucket. You'll also need something to plug the fitting on the resevoir. Then start the car and let the system pump out. Turn the wheels side to side to get all the oil out. Now pour 1-2 quarts of regular ATF into the resevoir and let it pump out, turning the wheels lock to lock again. This will flush out the system. Now reconnect the return line and fill the system with synthetic ATF, run the car for a while, turn the wheels several times and top off the resevoir if necessary.
hanshua
Blue Mounds, WI, USA
wouldnt turning the wheels w/o fluid in there hurt the steering system?
I mean.. it makes sense. No oil is bad.. no trans fluid is bad.. no blinker fluid is bad..
-Justin
95 ATX
K&N Silencer-Coneless, SFC's, two 12" kenwoods w/ 600watt amp and sony CD, CincySHO Cowl Hood, Removed secondary silencers, TPR bushings.
Comming Attractions: New 17" wheels (need rubber for them), SS y-pipe, new springs to fix my sagging rear, 24/26mm sway bars, Strut Tower Braces, Yamaha Badges :)
waddsn1060
Prospect Hts, IL, 60070
Im planning on doing this some time soon and was wondering if hanshuas comment was correct?
91 BLACK MTX
Some mods, nothing worth mentioning.
G-Tech Pro
0-60=6.32
1/[email protected]
GO BEARS!!!!13-3!!
SOON TO BE 16-3 AND SUPER BOWL CHAMPS!!!!
R.I.P. Dave Thomas. I will always eat great, and late.
Brad's Quote of the week. This week, The Simpsons
Homer- "Good things don't end in 'eum' they end in 'mania' or 'teria'"
olympic
Everything is still coated in oil after draining but if your concerned, you could start pouring the flushing oil into the resevoir as soon as you start the engine. That way it never runs while empty. You'll just need a buddy to help out with this method.
