Pothole then lots of ABS codes
NJSHO
Clean Your Shorts!
NJ
The other day I hit a pretty big pothole and got an abs light for a couple of seconds, then it went away. Today I went over a slight bump and the abs light came back on and stayed on. Grabbed the codes and there are quite a few:
Listed in order abs computer gave them:
22 (LH Front Inlet Valve)
23 (LH Front Outlet Valve)
24 (RH Front Inlet Valve)
25 (RH Front Outlet Valve)
28 (LH Rear Inlet Valve)
29 (LH Rear Outlet Valve)
26 (RH Rear Inlet Valve)
27 (RH Rear Outlet Valve)
31 (LH Front Sensor)
44 (LH Rear Sensor)
43 (RH Rear Sensor)
62 (Travel Switch)
I figure I might have a loose connector at the HCU or something since thats a f load of codes to get all at once. Anyone have any other insight?
hawkeye18
Sorta cares
Norfolk, VA
Yeah, i think you need to reseat the connector at the ABS computer and maybe beat it vigorously with the open palm of your hand for a few seconds to realign the electrons.
What? We realign electrons all the time at work! I just fixed a heater doing that yesterday.
Art5
white plains, NY
maybe connection of battery terminals are not too tight, that could be a problem sometimes too, however I never pulled codes, since i knew that in my 3 cases it was battery terminal issues. cleaned them, put back and was fine again.
