Post warranty work...
Spoilt22
Philadelphia, Pa
Passenger side turbo was leaking. Went in for power train warranty to replace it with a brand new one. Got it back and feels like it's a base line natural asp. V6... Is it just me or what?! Can you tell if the turbos aren't working ?
Flylow11
Nashville TN
Could it be your were used to the tune you were running? Outside of that maybe a scan tool that can read boost pressure on each bank?
Spoilt22
Philadelphia, Pa
I had it running stock for a while before it went in for warranty work so there wasn't an issue. It just feels it is lacking power. I will look into finding someone who has that tool to check each bank but in the meantime I'll run the tune I have and see what happens
Flylow11
Nashville TN
I really wish there were more gauges or a setting in the MFD were we could see things like boost pressure, AFR, or EGT .
EcoBoostSHO
Minnesota
Check your vacuum hoses on the top of the motor and make sure they are all connected. Especially the one right on top with 3 or 4 Hosea going to it. One of them has a habit of popping off and you lose significant boost...
Sent from my XT1096 using Tapatalk
Spoilt22
Philadelphia, Pa
Ok, I assume the hoses are on top under the intake cover. Anything else it may be. I'll let you know the outcome. Thanks.
SilverSH0
I just took that hose off yesterday to change plugs and had the hardest time getting it off. I pulled on it to the point where I thought I might top the rubber house or break the plastic. I would have never thought one could pull like in the video and remove it that easily.
EcoBoostSHO
Minnesota
Mine popped off on its own. No wrench and the car ran okay but noticeably slower.
Spoilt22
Philadelphia, Pa
That's what it could be.... It doesn't have the "torquey" pick up it use to have and has a slight hesitation when pressing the gas... Mind you I know stock has hesitations and lags but this car feels different. I'll post what I find later today. Thanks for the help.
EcoBoostSHO
Minnesota
They didn't put gas in it for you did they? 87 octane?
Spoilt22
Philadelphia, Pa
Well... It was exactly what you guys suggested. the vacuum lines and the big fat hose in front coming from the inner cooler going to the turbo wasn't even hooked up. fluid everywhere. All lines are in good condition. Clamps are all new. THANK YOU FORD LINCOLN MERCURY IN HATFIELD!!! F YOU!!!!!! They left all the plumbing for the turbos loose and the intercooler lines were all loose. Hardware that holds it down to the engine all loose as well. BIG F YOU. Thanks.
Spoilt22
Philadelphia, Pa
Already in the works. Thy will be done. Talking to my dealer whom I bought the car from and the dealer it went to for warranty work.
Spoilt22
Philadelphia, Pa
Just checked the car with mycal scanner from livernois, DTC, P0299 came up. Dealers have been notified. Will let you know what else they find. Thanks for the support guys.
SilverSH0
Have you hooked up all the plumbing so everything works again? If so, how far have you drove the vehicle? The P0299 appears to be a code because it's not making the boost it thinks it should be making. There's a high probability it threw that code when everything was disconnected. Connect everything, reset the code, and it probably won't come back.
Spoilt22
Philadelphia, Pa
After I hooked up all of the plumbing and hoses I drove the car for about a day and a half. Checked it just this morning and the code was there still after driving it for a day and a half. Keeping the code in the car so that dealer can see what happend. Car runs perfect now. Boosts like is should. No hesitation, no stuttering or pulsing.
