Mr95Gl
Mr Tire Iron
After just completing the upper 60K on my ATX, I have a couple of questions. I still haven't attempted to start it yet, as it needs a battery. When I was bolting back in the EGR Valve onto the intake, I accidentally dropped the bottom bolt, and for the life of me can't find it. I have the top bolt as tight as it can be. Will that cause a problem when attempting to start, or idle irractically? At least until I can source a bolt for it. Also is there a way to remove the top timing cover, without removing the accessory belt (limited on tools)? I wanna at least try to get it started this evening when I get home. Thanks!
