dmichel1
Hello All,
I have a 98 SHO with 105,000 miles that is currently undergoing a suspension overhaul. I recently had my struts, strut mounts, two front springs, front and rear sway bar endlinks replaced. I had a bad clunking/rubbing prior to this overhaul that I thought would go away but it persists despite the shocking bill. The shop is very helpful and they even ordered replacement struts on the inkling that they got two defective rear ones. Last time I went to pick up the car they took me into the shop, told me the noise was still there, put the car up on the lift and told me how they just couldn't get my rear sway bar to sit flat, and how contorted the endlinks were with this "big bar." They even showed me how the bar was rubbing wrong on the plastic donuts. they claim that if they disconnect the endlinks, the noise goes away, other than it clanging around done there unbolted.
Now, this 26mm bar has been on the car for 40,000 miles with what some call the "polyurethane noise" (which I can tolerate) but nothing that resembles the "clunk/rub" that had developed in the 5,000 miles prior to this suspension work and which persists now.
The shop ordered the same sized endlinks that were on the car when I brought it in, from Energy suspension. I remember when the bar was installed long ago, the (different) shop told me that they had to "fiddle" with it to sit right. After the installation there was no noise nearly as intrusive and harsh as what I have now.
Obviously, the question is whether there is some trick to making the bar sit flatter that will **** this horrible noise, some tip I can pass on to the mechanic so I can enjoy how nice a new, non-clunky spensension can be.
Thanks for any help,
Bests,
Dave M
Bests,
Dave M
