You will never have to replace the plug well seals again if you stop the REASON they are leaking. Get rid of the vacuum in the plug well and it won't suck oil in. I can hear you all thinking now, "I don't have vacuum in my plug wells". Yes you do. The plug well on the Yamaha is a sealed unit, with the seal on the bottom and the spark plug boot on top. When the air in there heats up to 160 degrees, it expands and the overpressure forces some out through the spark plug boot. When the engine cools down, the air cools down and shrinks, causing a slight vacuum in the well. The spark plug boot at the valve cover seals so well that the only other place it can get air is from under the plug well seal at the bottom, which is surrounded by hot thin oil. All of the buggy guys that used this engine figured this out right away.
There are several ways you can address this vacuum problem:
1) Use different spark plug wires that don't use the valve cover seal.
2) If you insist on using the Ford spark plug wires, slip a small piece of plastic cable tie in between the boot and valve cover when pushing the boot on the final 3/4". This allows a microscopic path for air to go in and out easily.
3) Heat up an ice pic and melt a tiny hole in the silicone boot, also providing an escape path for the air.
