Please, use good oil....
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
I was at bobistheoilguy.com, and was just kinda looking around and i found this
no only is the link to that pic bad, but scorll down a few replys and you will see some sad stuff.
Please, use good oil, and change it.
:eek: doh headbang
<small>[ December 01, 2003, 02:49 PM: Message edited by: Camarok ]</small>
SHO--ripper
928 Euro
winsted,CT
GTX every 3k thumb
I like to run it dry every once in a while to make sure the motor's running well :p J/K
Blue-By-U
CT
That sludge is gross eek! Ditto on the Castrol GTX every 3,000 thumb
MilTownSHO
Horicon, WI
Motorcraft filter and whatever the cheapest oil is for the 92, it burns right through it anyhow.. headbang
Motorcraft filter and oil for the 98 ONLY
TYSHO
Earth
Like the manual say's, "every 7,500 miles." Every 7,500...Pennzoil hail Pennzoil hail Pennzoil hail
Camarok
SilverSHO:
I burn a quart of GTX every 500 miles. Does that count? :mad:
Well when i had my camaro, it proabaly went through a quart every time you started it in the morning :p then the engine swap from **** went wrong, and it is now gone :confused:
TYSHO
Earth
sdpatt:
TYSHO:
You're kidding. Right?
I totally forgot about that post and this thread. Never would I dare to put in Pennzoil. Castrol and/or Motorcraft only. You should've seen the heads and bottom end of the 93, previous owner used Pennzoil and to add to that 10W-40.
revhardSHO
Seattle, WA
Lets not get started. All the sludge and gunk you seen in that oil pan is pure negelect. That is not the result of a cheap oil, even the holyest of holys; the might "CASTROL GTX" would do the same thing. If you dont change your oil, thats what happens. Ive run ELCHEAPO 10w-30 in the beater for two years now, 40K, and the internals are clean as a whisle. Penssoil is fine also. There is a pic.
HopefulSHO
Bellevue, NE
Pennzoil is good oil. PureBase is probably better than GTX. GTX thins pretty quick compared to a lot of dinos..but still performs great in the reccomended intervals.
