VW_Factor
Ive never owned a car with so many sensors, etc..
Otherwise.. Something Ive noticed after having this 89 for a while..
If the engine is still fairly cool (just started moving the temp gauge), you can romp in the loud pedal and it will light up the tires.. First and second gear..
After the engine is fully warmed, into the "ma" range on the gauge of "normal" it will no longer light up the tires as such.. It requires some clutch work to light them up..
This tells me that perhaps a sensor is not allowing something to happen in the intake.. (Like the secondaries not opening, or opening too soon, allowing no low end torque)..
Is there a sensor that is normally attributed to this behavior? Or is this just something normal that this SHO motor does?
