DeaconBlue
Although street, autocross and road racing require different alignment settings, I thought I would throw in a set of road racing alignment specs into this discussion. These are from Eric at Rickety Engineering. They were originally from either Vadim or Doug.
front;
caster +4.5 to +5.0 (move the SF as far forward as possible)
camber -1.50
toe 1/16" out total with stock strut rod bushings
toe 0 with poly or TRP bushings
rear;
camber -0.05
toe 1/16" out with stock strut rod bushings
Of course total thrust angle must be zero.
On the street you would want less front camber and slightly more rear camber (something like -0.20)
front;
camber -1.50
rear;
camber -0.05
