shojay
What is the proper procedure for setting the clutch pedal/cable after installing a new clutch?
J
J
Shoaz said:Yikes! How have you done manual adjustment in the past?
The cable tension does all of the necessary adjustment and the automatic quadrant is supposed to keep the cable tight. Lifting up on the pedal (at any time in any gear) will pull the cable taught, assuming the automatic adjuster in the quadrant works.
However you've done it manually in the past should work on a new installation as well.
Shoaz said:Perry,
Every time I've been under the dash (clutch changes, cable changes, etc.) or held a pedal assembly in my hand, as soon as you pull the pedal off tension the quadrant will snap as far as the cable slack will let it go. In other words, it operates just as I said. I'm not sure what you're disagreeing with.
If you've ever had a pedal assembly out of the car, you can push the quadrant around and let it snap full travel if you want just by simulating pulling up on the pedal.
