Pcv ?
Sho-Driver
Peter Pan
The Garage.
K-Dawg said:
Summit sells the Moroso ****** (with slit) and check valve separately.
Check Valve $19.69
Weld in ****** (with slit) $10.69
Total - $30.38
The full Moroso set from Summit is $59.88.
The Mr. Gasket set is $31.99 from JEG'S and it has two ******* and two valves, but the ******* don't have the slits.
I think I might just buy the ****** and valve separately from Summit so I don't have to bother with cutting the slit.
I bought the kit and had an extra bung, check valve, etc. left over. I ended up selling the other half for $20, IIRC.
EDIT: You may want to check your links as they are a no-go.
