Parts numbers and shyt ;)
EliminatorSHO
Palm Springs CA
So Im looking to replace front end parts on my 91 MTX.. I found part numbers for the coil springs (thanks guys) and suggestions for KYB struts Excel G but no part numbers.. same thing with lower control arms and ball joints.. Rockauto (and others) is not much help, not to much listed for SHO. Any suggestions or help?
Struts (front and rear)
Sway bar end links and bar bushings
lower control arms
Thanx
zoomlater
Seattle, WA
Take a look at this post (thanks Nick!), there is a link to Nick's list of part numbers, at the bottom of his page you can select the suspension tab. You will need to cross reference them from what places like Rockauto have listed. You can also try Shosource for parts
EliminatorSHO
Palm Springs CA
I opened it and all there was were filter number
EliminatorSHO
Palm Springs CA
OO
OOOOOPS My bad.. I downloaded it and saw the tabs.. Im sometiimes slow, ty!
zoomlater
Seattle, WA
Glad it works for you, an excel type sheet should show up and there should be tabs at the bottom with different options
BaySHO Performance
SF South Bay
Don't have all the parts in that spreadsheet you can buy these days. From my records:
Struts (4 KYB Excel-G) $290 SHO Source
Front Sway Bar End Links (2 Moog greasable) K8702 $24 Rock Auto
Rear Endlinks $32 SHO Source
Sway Bar bushings SHO Source
Front Lower Control Arms (2) $91 SHO Source
