My trans is currently out of the car, I need to split the case and reseal it - leaks in the high pressure area above the ring gear.
Is this seal any more difficult or not to replace with the transmission in the car? I have a 95 with around 92 K miles on it, thinking of letting sleeping dogs lie . . . .
Thanks for any advice - zak
John,
I'm not sure if I understand exactly where yours is leaking from. Are you talking about where the two case halves meet up above the ring gear? If so, then splitting the case and resealing with Permatex Anaerobic sealant is your only option.
The axle seals, while they can be changed out with the trans mounted to the car, it is much easier to remove and replace those seals with the trans not mounted to the car. When removing you'll need to whack a flat head screwdriver through the metal part of the seal and pry on it. Many people try to slip a flat head under the lip of the seal and what they end up doing is damaging the case there by gouging it. If you're careful it can be done that way, but take your time and be precise with the screwdriver. Remember, your case is made of aluminum.
When replacing the axle seals, whether using Ford replacement parts or aftermarket, I generally put a small bead of anaerobic sealant around the lip where the seal will meet the case prior to installing it. The Ford seals have a rubberized seal dealio already on it, but when they sit on the shelf aging, I just don't trust it. To be sure that it's sealed right the first time, use a little bit around that lip.
The shift shaft seal is a breeze either way, with the exception of having to jack the car up and crawl up under the car. That would be the hardest part about that seal. Again, a small bead of anaerobic sealant around the outer edge where it will mate with the case is good cheap insurance. You don't need to use a huge amount, just a dab'll do it. If your trans is out, just replace the seal for good measure. There's nothing like getting everything installed, thinking you're done and then finding out a month later that the seal needed to be replaced. It's cheap, it's easy. Just do it and be done with it.
If that doesn't answer your question just let me know.
For future reference, Josh carries all those seals on his website to my knowledge. If he doesn't have one, the part numbers are listed for them.
