Parking brake light flashing while accelerating
Mike Stitzer
PA
This is wierd. I've only noticed this in first gear, but while accelerating at WOT in 1st gear I will see the E-brake light flicker. THis seems to happen when the tires are on the verge or just starting to spin. In other words when the secondaries open up the car squirms a little then I see this light on and off. THe brake is not on. It's not sticking or anything. I haven't tried a burnout yet to see if it's totally related to wheel spin, but i just can't figure this one out.
Mike
S
slosho
Guest
The brake fluid in the master cylinder should be filled to the top. There is a low fluid level sensor in there.
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a "PCV" line
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
gregr
Orange County, NY - USA
Same deal with my 93.
I filled the resevoir to the top with fluid, and like magic the annoying light dissapeared!
Easy fix.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
ghostrider
Mt Juliet, TN
I found in my old 91 that the parking brake lever was loose and it would just slightly engage when accelerating or slowing down. I wouldn't actually slow the car down with it came on. Would just have to play with the pedal a little and it would work fine.
Rob
EX-91 SHO+ White with tan leather int. 17" Niche Spike wheels
[This message has been edited by ghostrider (edited 11-21-2001).]
sho 'nuff
Kansas City
Mine has been doing the same thing...funny thing is I just refilled the resevoir recently(?)
'93 green atx
LeBra mini-bra
Gen 3 SHO emblem on trunk lid
Blue LED Fishtanks and Corner Markers
bosch platinum +4 spark plugs
RActive Heat shield filter
Hayden TransCooler
xenon head and foglights
12" jl audio power wedge box
200w kenwood amp
NEONS!
Duff
Box Elder, SD
Brake fluid normally doesn't dissapear--chances are that if your fluid level has dropped, you've got a leak!! Make sure you check for leaks, especially at the calipers. I had the fluid level drop on my other Taurus and found that the inside of one of the back wheels was coated with brake fluid.
The level of the brake fluid in the reservoir will continue to decrease as the pads and rotors wear and more and more fluid fills the pistons in the calipers. Pressing the pistons back into the calipers when replacing the pads will refill the reservoir. If you have topped off the reservoir due to a low level light, you may have an overflow of the reservoir. If your rotors are near the minimum thickness and the pads are completely worn, you can get a low level light without a leak. Re-check the level after the pads and rotors are replaced and the reservoir is again near the max level. If it is lower than normal at this point, you should check for a fluid leak if you haven't already spotted one when replacing the brakes.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
Mike Stitzer
PA
Thanks for the advise. I topped off the reservoir yesterday and haven't seen the light flicker since.
Mike
