Are all the green SHOS the same cuz mine changes color and its green at some parts lighter green in others and a almost blue in others I need some paint but want it to match exactly
The reason I would like to know this is because I am doing some body work on the rear quarter panel and want it to turn out decent I hate doing body work but the looks of the SHO are worth it to me body work is not one of my good things I would much rather be wrenching than sanding and bondo and more sanding and more bondo. The reason that the color matching up is worring me because I have a couple small rust spots other than the one big one and I dont want to be able to see little taped squares in a few spots and I really like the way the paint changes and would like to keep that effect any suggestions?? Sorry so long
What would you recommend sparring the paint at SSI wise, I have a compressor and a paint gun. I am strapped for cash and a professional paint job is far too expensive right now and chances are if it don't look how it should the whole cars going black. I was going to use the many thin coats method.
Emerald green is NOT a pearl,the frost colors were, it is a metallic and the size of the mica and the PSI plus application thickness effects the color the most. X2 on going to a paint jobber such as car quest as most of them now have a hand held color matcher,that gives you the best results.
