"packable" rear wheel bearings
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
The ford shop manuals state that a bit of play in the wheel assembly is "okay" with good, torqued to spec wheel bearings.
How much is "okay"?
I had a rear wheel off the other night while attending to a sticky parking brake cable, and during the re-mount of the tire, I noticed a good amount (IMO) of play or wobble in the bearings. I could rock the tire back and forth (in any direction) nearly a 16th of an inch. :doh: I checked the other side and found the same results.
I have since "adjusted" the bearings according to the shop manual, but the play persists. I have no noticable grinding or resistance in the bearings, and they make no audible noises. Tires spin free.
Is this considered normal? Its kind of freaking me out! :eek:
Racer X
SHO Pilot, Retired
Connecticut
Sir, what you need are some 1990+ spindles with the non-adjustable bearings. Problem solved. :thumb:
Otherwise... 1/16th at the top of the tire isn't terrible. 1/16th at the top of the hub, however, is a problem. Have you tried repacking the bearings?
Ishodu
May not be the right way but when I used to do these bearings I used to snug them up until I could feel a little Resistance in spinnig the wheel, then back it off just enough so that it would spin freely.
bmytych
