outside keypad removal?
newby92
3.2 swapped 95
ohio
just curious as to what all has to be removed from the door to get to the keypad... can i just remove one and install another? i ask because the 7/8 key on mine is not working hardly at all and i need that button to open the door. what holds it in place... just clips? do i have to remove the window track to get to it? thanks guys
mrecoolgar
SHO NUP
Hershey-PA
The inner door panel needs to be removed.
Then there is a clip that needs to be removed.
It's to the front of the keypad.
It will slide off horizontally towards the front of the car.
Then tilt the front of the keypad towards you.
The back of the keypad sandwiches the door skin and will release as you tilit the front.
Don't forget the wire harness connection.
newby92
3.2 swapped 95
ohio
thank you so much... im gonna be doing this soon and just needed to know what i was in for... by the way when you say tilt the front of the panel toward you i assume you mean from the outside of the car right?
qiksho
SHO Addict
Fargo, North Dakota
You can program a new code that will not use the 7/8 button if it is barely operable.
This would eliminate needing to replace the unit...;)
newby92
3.2 swapped 95
ohio
i thought in order to program a new code you had to replace the entire keyless entry box in the trunk? am i mistaken?
No, you can change the default code by changing the box in the trunk, but you can also program alternate codes that will work until the battery is disconnected. That way, you can program all your vehicles for the same code...
qiksho
SHO Addict
Fargo, North Dakota
Every vehicle has a "master code". IRC you must replace the box to change the master code. You can however use the master code to program slave codes. These slave codes can be changed anytime you want with the master.
I have been using a slave code on my 92 for 6 years now. This way I can change it when I switch girlfriends and also ensure i don't wear out certain buttons.
newby92
3.2 swapped 95
ohio
ok so how do you program a slave code... i am searching right now and not finding out how to actually program it. every post i have came across is for the gen 3. anyone remember how to do this???
qiksho
SHO Addict
Fargo, North Dakota
I know it is in the owners manual. It is the same procedure for all fords of that vintage IRC...
I will do a search to see if I can pull it up.
If I remember correctly you type in the master and then you can enter the new code.
newby92
3.2 swapped 95
ohio
yup tried it and it didnt work. i must be doing something wrong. ill go out in the rain right now and try it again.
SUCCESS!!!!! im soaked but it worked. it was to the point i was having to carry a can of compressed air to blow the water out of the pad when it is raining just to get the seven to work. seriously it takes me like 10 minutes to get in the car sometimes. now the code is changed and i have no proplems... thank you guys so much.
