Looks like it's coming from the oil filter/oil filter mount/oil cooler area. I would check very carefully for rips/holes in the hoses in the area and loose filters. the mount has a tab that is supposed to butt up against a pin on the block; check to make sure it is.
Edit: about the "grand" offer: ba-zing! That was funny. I lol'd a little bit.
all those hoses by the oil filter run coolant, there are no hoses with oil on the SHO engine that I know of.......
if its leaking by the oil filter, I give u 4 options, lets start from the top of the engine, you gotta treat oil leaks like a volcano, go up until u can't find anymore wet spots, cause you might see a lot of oil on the oil pan, but its just running down and could be from something else... valve cover gasket, this would be the highest thing, then maybe your actual oil filter is leaking/loose... it happens, then your oil cooler could be leaking, try to take the oil filter off, inside is a big nut, see if its tight... if not tighten it, or a gasket could be leaking, i think there is a gasket back there, but I could be wrong...... I work on so many different cars now that I forget about SHO stuff... imagine that
then the actual oil pan could be leaking.. but remeber start from the top and work your way down.... and I'm not saying just cause your valve cover leaks and drains oil all down the engine, that its not possible your oil pan is leaking as well.... but u gotta start somewhere....
if its too nasty for u to comprehend, get a lot of cleaners, brake cleaner, whatever, and hose it down and wipe it clean, then run it until u see oil comming from somewhere.. this might happen instantly, might take a few minutes, might take 15 minutes....
or find a SHO enthusiast around and have him help you out, I'm sure someone would help you out, **** maybe even help you fix it or them just fix it themselves for you, if you were down in Florida I'd help you out.... just gotta find someone in CO with that attitude and kindness...... SHO people are a helping community
lord knows sometimes I need an extra hand or have questions of my own with these cars
