gurucomputers
I just pulled all three cam seals and the front main out. I am thinking that the major leak was from the rear cam seal cause the sensor was full of oil. I just need an educated opinion... By looking at the photo would you consider some of the leak from the rear valve cover. Also the other photos are of the intake runners on the heads. There is probably a 32nd to a 16th inch of sludge built up in there. I wiped the upper inch of one out with a rag. What it the best way to clean these out all the way down to the valve.
