91PDXmocha
Hey , does anyone have the part # for the oil filter adaptor so I can run a remote set up ? Transdapt , mr gasket somthing ? thanks
You might want to check this out as I am using this set up in my turbo sho
http://www.glowshiftdirect.com/oil-cooler-sandwich-adapter-34-unf-16.aspx
Ok, forgive my ignorance, but how the **** do those sandwich thingies work? Does the oil come up through the center hole and out the sides? Does it go through the filter first, then out the sides to the cooler?
If I were to, say, repurpose the stock ATX cooler as an oil cooler, would I simply replace the stock oil cooler plate with the item referenced above and run lines to the cooler? Would that severely impact flow?
I'm just trying to separate all the fluid paths. As it is, the stock ATX mixes coolant with trans fluid, and coolant and oil (well, not mixes, but swaps heat with). The only fluid that has its own path is the PS fluid. I aim to fix that by putting in a separate trans cooler (with thermostat) and bypassing the radiator, and then using the stock trans cooler as an oil cooler and bypassing the oil/coolant thingy.
I don't think he was asking about the stock oil flow (****, I hope he's already got those pages, considering where they came from), but rather how the aftermarket oil cooler sandwich thingies work.
Those are fine for low flow transmission cooling applications, but I wouldn't use them for engine oiling.That's what these guys are for:
http://www.bulkpart.com/Merchant2/m...uct_Code=708-4739&Category_Code=&Store_Code=2
Although, your solution might work better (and would certainly be more compact). I'm too pumped full of sleeping pills to be able to tell the difference. I'll look again tomorrow lol.
http://batinc.net/thermos.htm
OT1 in nothing less than 1/2", OT2 in nothing less than -10 AN. Remember, you're dealing with an oil pump that can flow in excess of 10 GPM. Small bore oil lines will **** your engine.
If you want to do a remote oil cooler, from a plumbing simplicity perspective (fewer fittings, potential leaks, etc.), a thermostatic sandwich adapter between the block and the oil filter is the best solution. There are two ways to do this on the SHO V6:
1. Use an M20-1.5 thermo sandwich adapter with an M20 straight thread ****** to adapt it to the block thread, but this now limits your filter choices to something with an M20 stem thread.
2. A better solution is to get a Mocal 3/4"-16 thermo sandwich plate, and use BAT's slick 3/4"-16 to M20 adapter ****** in the block, now the oil filter thread on the thermo adapter is still 3/4-16, and you can attach big-ass FL1-A style filters there.
