O2 sensor bank1 sensor 2
tavius
arizona
I know this sensor is the one before the convertor , but which one is it?
Mr Anonymous
Tire Wall
Nope, it the downstream (after the cat) sensor for the rear bank. It will be the furthest sensor rearward on the y-pipe.
ScotSHO
Lewiston, NY
I believe the O2 sensors after the cats do not factor into the air/fuel mixture, correct? If they are working correctly and they generate a code, then the cat is potentially fouled.
I changed one out on my 98 Expedition, check engine light went away. Bad O2 sensor.
