O/D Button fixed
Winterhawk
1993 SHO ATX
Independence, Missouri
With the help of you guys once again I was able to fix my SHO. My factory Service manual did not make it clear on how to remove the lever and console. I did a search on this forum and found where a member said just remove the clip and 1 screw in the console. Way to easy. Thanks. I found a broken wire and I re-bent the tab in my button so it will make continuity. Now my O/D comes on and off on the dash when I push the button.
I was at Fords today and the wires to the O/D Button are no longer available. The shift handle assy. is no longer available either. They had the O/D Button for $33.00 plus tax.
The other thing I wanted was a new coolant level sensor. They are not available from Fords anymore and Auto Zone and Advance can't get it either. Any ideas on the coolant level sensor?
