not fixed
shoandtbird
gta canada
i went out and got a code reader cause my problem came back and its driving me crazy.The shop i went to said its fine just drive it ya no!!! the codes i got are cm codes with koeo they are 14c ignition profile pickup (pip) circuit failure,19c cylinder identification(cid) sensor failure,49c spout signal problem, and 91cHEGO(HO2S)sensor signal out of range/always lean. My problem is no low end power and it will stall on it own at a light if i sit for to long it doesnt give much of a worning the rpms drop to 500 then jump to 900 and the she dies !!!! any one no some of these codes or had this before i did the timing belt cps and all new plugs and wires this problem was there before doing all that
