myotis1134
1992 MTX
-New steering rack - Detroit axle - check valve cleaned and transferred to pressure port
- All new hoses - Car Quest/RockAuto
- New steering sensor - SHO Source - correctly hooked up to connector
- Did not replace - pump, cooler, or reservoir - cleaned out cooler and reservoir
- Approximately 3 bottles = 1 qt Royal Purple steering fluid added
I added two steering fluid bottles last night, which filled the reservoir. The level was slowly going down into the pump/lines, so I left it alone until today.
Today, I started the engine, and began to turn the steering wheel left - to flush out air. Immediately the wheel began forcefully turning to the right, and fought me when I attempted to stop it. I killed the engine and checked the reservoir level - adding the last bottle of steering fluid - figuring an air pocket was the cause.
Started the engine and got the same aggressive turn to the right, so I let it go. After turning all the way right, I lost power steering, and saw fluid on the floor.
I haven't crawled under to see what is leaking yet - gonna let the kitty litter soak up the puddle for another 30 minutes. I looked at the reservoir/pump area - no leaks or signs of pressurized steering fluid - same for the cooler. I'll post again when I find out what blew.
I had everything including the intermediate steering shaft disconnected during the replacement, and the steering wheel got spun a few times during installation of new parts. Is there a sensor on the steering wheel that I may have aligned at "turn right like a bastard"? or is something else going on here?
I'm certain the pressure and return lines are correctly connected to the rack. I did put a tiny amount of black gasket maker on the bottom 1/4 of the sensor threads - to make sure none of it would get into the port. All the new hoses have nylon or some sort of plastic o-ring gaskets, but I made sure everything was tightened firmly. I inserted the check-valve with the cap-end towards the outside of the port - facing the hose - hopefully that isn't backwards.
Any opinions are appreciated.
Hose diagram I referred to:
