Wsho
I would like to take a Gen 4 SHO combined it with a P100 Tesla. Then it would be called SHO-Elect...
The only time that will happen if I win the lottery.
7.3 liter that doesn't even make it to 500 hp? For 9 grand?
Color me unimpressed.
That article is misleading as ****. "Original block and heads" means just the castings. The heads have been heavily worked, rotating assembly built up, aftermarket pistons, custom ground roller cam, new intake, and on and on and on. You're essentially looking at a mild pro stock motor that needs constant service and little to no street car practicality.
What's the price tag for all of the above including labor? $5000? $10,000? For current results and future projections that are no better than your run of the mill FI junkyard LS? From a motor over twice the size but less torque than a stock ecoboost? Color me unimpressed as well.
Also over priced, lol.
I agree with this...Of all people, I figured you would see the potential here....
7.3l in the same footprint as a 351cleveland. Also the insanely flat torque. And..... You can just add a supercharger and a tune to hit ludicrous power.
But let's just gloss over all that. Dat ting cost de dollas. I'd radda spend 10k to get 600hp on my ecoboost unreliably. (I have no idea actual costs or reliability, just trying to get someone to research anything)
I just think 9,000 is a LOT of money for an engine you then have to "build" to get serious power out of. ****, it would be cheaper to start with a dart special high performance block, and strait up build a race motor, good to 1,000hp +.
For me its just about shaking things up and going back to NA....at least in the Notch.
I currently have a 331 Dart block fully built with a Vortech V3 Si slightly tweaked supercharger. Its currently putting down around 600-650
Have looked at the LS option more than once, just can't do that to the ole blue girl.
Biggest issue for me is I'm NOT going to put a cowl hood on the car, LOVE the notches clean lines.
From everything I have heard that might be impossible with a 7.3
https://www.summitracing.com/parts/...vnv-gJuMC2ksF2q3wHX0ScRegUKTiZWIaAmtaEALw_wcBLink the price for the crate/full build. I'm ready to compare notes
That "flat" torque curve starts at 4500 RPM, whereas the stock motor has already peaked before that point and probably can't spin past 6000 RPM. All I'm saying is that the full blown race engine in that article is nothing unique or special, bears no resemblance to the original motor, and it's not even streetable power. Unless you like cruising at 5000 rpm and stopping every hour to readjust your valve lash.Of all people, I figured you would see the potential here....
Gotta wait and see what ford does with it. Its clearly set up for towing, not going fast. Its a truck motor.That "flat" torque curve starts at 4500 RPM, whereas the stock motor has already peaked before that point and probably can't spin past 6000 RPM. All I'm saying is that the full blown race engine in that article is nothing unique or special, bears no resemblance to the original motor, and it's not even streetable power. Unless you like cruising at 5000 rpm and stopping every hour to readjust your valve lash.
Or for <$500 you can pick up a salvage 5.3L, just gap the rings, then add boost and pick whatever horsepower you want while maintaining full drivability.
Now if this 7.3L was 32V with TiVCT, I'd probably have a slightly different opinion. But as a pushrod crate engine, it costs more than a crate LS3 yet doesn't even compete in terms of performance as far as I can tell. It would probably make a decent boat motor though.
