OK one more time!
The GenI idler pulleys, both, the pulley for the six ribbed belt and the pulley for the four ribbed belt, have an NSK bearing number
BD20-15DWA.
This bearing was made specifically for Ford and is NOT available in the "aftermarket" parts stores, nor is there a comparable bearing available from the various bearing distributors.
It is not a common sized bearing, period.
This same bearing is used in the pulley of the Gen III SHO. The pulley is about $30. Press out the bearing, and press it into your Gen I SHO pulley.
The new Gen I pulleys are $75 and $95 respectively. For $60 you can replace both bearings with very little effort.
Another forum member is in the process of trying to find a less expensive way to replace these bearings.
But for now, the least expensive way is to do as posted above; use the Gen III pulley, or take the bearing out of a Gen III pulley.
rangerj
