Sho Nutz
I am kinda stumped on this one,
If you barely touch the accelerator it will move, but if you try to give it to much the car falls on its face. after about 3k rpm you can go WOT without a problem. Pulls hard all the way to redline. Also if you shut the car off and then go to restart before it has cooled, it cranks over for a long time and you have to apply a little throttle to get it restarted and then it idles at just under 3k.
I tried pulling the check engine light codes but I cant seem to get any or I am just doing it wrong.
Can someone give me an idea of what this may be and give me the procedure to pull the codes ?
thanks,
Pete
Ok, finally got around to scanning system and found the following codes..
113--IAT sensor high
118--ECT sensor high
121--TPS sensor out of range
123--TPS sensor high
126--MAO or BARO sensor out of range
157--mass air flow signal low
519--PSP switch open
528--system shows voltage at pin 10, clutch switch ?
542--Fuel pump open, bad ground or always on.
This point to one problem or an area of probs ?
I tried pulling off and clening my MAF, but it didnt help, silly question though, I thought the MAF sensors had a screen in them or something, this was just open space in it...
well either way, I hope someone has an idea of what I need to do, let me please and thanks.
Pete
<small>[ June 23, 2003, 11:15 AM: Message edited by: Sho Nutz ]</small>
thanks,
Pete
Pete
